1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Alarm Limits
To: "Pierrick Hanlet" <[email protected]>, <[email protected]>
Date: Thu, 19 Mar 2009 06:54:13 -0500
Hi Pierrick,
You can use a calcout, but not the way you are doing it.  You are not actually using the output of the calcout to write the values to the .HIHI field, you are trying to use the ai record to read the values from the calcout:
record(ai, "$(user):Q1ReadCurrent") {
        field(HIHI, "$(user):calcQ1I_HiHi.VAL")
        field(HIGH, "$(user):calcQ1I_High.VAL")
That won't work, because the HIHI etc. fields are not input links.
You need to do something like the following:
record(calcout, "$(user):calcQ1I_LoLo") {
        field(DESC, "Q1 I Min Major limit")
        field(PREC, "3")
        field(INPA, "$(user):Q1SetCurrent.VAL  NPP NMS")
        field(INPB, "$(user):ILimMajor.VAL  NPP NMS")
        field(CALC, "A-A*B")
    --> field(OUT, "$(user):Q1ReadCurrent.HIHI  NPP NMS")
You might also want to change under what conditions the calcout writes its output: only on change, etc.
From: [email protected] on behalf of Pierrick Hanlet
Sent: Thu 3/19/2009 6:10 AM
To: [email protected]
Subject: Alarm Limits
Can one use the output of a calc or a calcout routine to set values for HIHI, HIGH,
LOW, and LOLO?  When I load my database, I always get errors in these lines.  Is
there some sort of special incantation that I must do?
Here's what I have.  I've used camonitor to check that all of the records leading
up to and including the calc records work as expected.  For the calcout routines,
I have a value between 0<= VAL <=1 for ILimMajor and ILimMinor.  The calcout
records appear to do what I want them to do:
record(calcout, "$(user):calcQ1I_HiHi") {
        field(DESC, "Q1 I Max Major limit")
        field(PREC, "3")
        field(CALC, "A+(A*B)")
record(calcout, "$(user):calcQ1I_High") {
        field(DESC, "Q1 I Max Minor limit")
        field(PREC, "3")
        field(INPB, "$(user):ILimMinor.VAL  NPP NMS")
        field(CALC, "A+A*B")
record(calcout, "$(user):calcQ1I_Low") {
        field(DESC, "Q1 I Min Minor limit")
        field(PREC, "3")
        field(PREC, "3")
        field(DESC, "Q1 Magnet Readback Current")
        field(PREC, "3")
        field(INP,  "$(user):rampQ1Current.VAL NPP NMS")
        field(EGUF, "10")
        field(EGU,  "A")
        field(HOPR, "2000")
        field(LOPR, "0")
        field(LOW,  "$(user):calcQ1I_Low.VAL")
        field(LOLO, "$(user):calcQ1I_LoLo.VAL")
        field(HHSV, "MAJOR")
        field(HSV,  "MINOR")
        field(LSV,  "MINOR")
        field(LLSV, "MAJOR")
        field(FLNK, "$(user):Q1RampCurrent.PROC")
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Re: Alarm Limits Dirk Zimoch
Alarm Limits Pierrick Hanlet
Prev: RE: Alarm Limits Owens, PH (Peter)
Next: Re: Alarm Limits Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
