1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Firewall configuration?
Cc: [email protected]
Date: Fri, 6 Feb 2009 17:14:20 -0500
Thanks - this seems to work! I used cainfo to get the host names of the IOCs we were trying to reach, and traceroute to get their IP numbers. Setting EPICS_CA_ADDR_LIST to point to these two IOCs specifically seems to let everything work with the firewall on. Thanks!!!
On Feb 5, 2009, at 4:48 PM, Mark Rivers wrote:
Hi Chris,
I had a similar problem with the standard BNL firewall on Windows (Trend
I think?).  I think the problem was as follows:
- EPICS sends a multicast message to find the PVs on a port you have
enabled
- The client responds, but because the outgoing message was a multicast
the incoming port was apparently not opened for that server.  I proved
this by setting EPICS_CA_ADDR_LIST to specifically include the IP
address of the server, and then it worked.  You could try that.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Chris Jacobsen
Sent: Thursday, February 05, 2009 3:15 PM
To: [email protected]
Subject: Firewall configuration?
Hi - I'd like to have a firewall configured on my linux system but
when I turn it on then I get a timeout when accessing EPICS variables
on a remote system.  I thought it would be sufficient to enable TCP
and UDP access on ports 5064 and 5065, since I'm running with a
"standard" EPICS build on the latest release.  Can anyone suggest what
else I need to set in a firewall configuration to allow EPICS to work?
Thanks, Chris Jacobsen
Firewall configuration? Chris Jacobsen
RE: Firewall configuration? Mark Rivers
Prev: RE: Firewall configuration? Allison, Stephanie
Next: problem using the gpib-asyn support Maurizio Montis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Firewall configuration? Mark Rivers
Next: RE: Firewall configuration? Allison, Stephanie
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
