On Wednesday 07 January 2009 11:46:19 URIOT Didier wrote:
> I tried to compile EPICS base 3.14.10 on a windows computer with gcc 3.4.5
> I followed the install instruction, and compilation started correctly but
> after a fews secondes I had the following message.
> g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -I. -I../O.Common -I. -I..
> -I../../../include/os/WIN32 -I../../../include ../tcpSendWatchdog.cpp
> ../tcpSendWatchdog.cpp:73: internal compiler error: Segmentation fault
> Have you already see this type of problem ?
Yes, it's weird. Sometimes I can get this file to compiler when I have
HOST_OPT=NO in my CONFIG_SITE file, but not always. A colleague has no
problem on a different PC. However even if you get past that problem you may
hit another one (which I'm also seeing on a cygwin build) that I haven't
worked around yet.
The Microsoft compiler (which you can download for free) does work for me
though.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- EPICs base MingW32 compilation failed ! URIOT Didier
Gateway fails with "epicsMutex pthread_mutex_lock failed: error Invalid argument" Mark Bennett
<2009>
Re: EPICs base MingW32 compilation failed ! Jens Eden
<2009>
