Hi Tom, Happy New Year!
Thank you very much for your advice. The return value of the "time" command
seems to indicate that my vxWorks clock is off by 6 hours, will talk to the expert
doing this.
Best regards,
Dehong
----- Original Message -----
Date: Sunday, January 4, 2009 1:53 pm
Subject: RE: Timezone setting with R3.14.10
To: Dehong Zhang <[email protected]>, [email protected]
> How does the local vxWorks clock get set?
> Epics time is # seconds since 1/1/1990 00:00:00 UTC and the basic
> vxWorks clock is from 1/1/70 00:00:00 UTC. It should be easy to look
> at the return value from time() and the seconds field in a running
> record and see if the # seconds there is UTC or CST by just taking
> that number modulo the # seconds in a day.
> The timezone fields are only used for local time display purposes and
> would not impact what a camonitor would report.
> This is what we do:
> putenv("EPICS_TS_MIN_WEST=300")
> # New DST changes for 2007 Eastern Time Zone US
> putenv("EPICS_TIMEZONE=EUS::300:031102:110402")
> We also set the local vxWorks clock from NTP at the start, this makes
> the DST calculation go correctly. The calls can be made from the
> startup script.
> ________________________________
> From: [email protected] on behalf of Dehong Zhang
> Sent: Tue 12/30/2008 11:36 AM
> To: [email protected]
> Subject: Timezone setting with R3.14.10
> Hi Everybody, Happy New Year!
> Recently we upgraded to 3.14.10 (on vxWorks 6.1). We are trying to
> use the time
> from the local vxWorks system, instead of the EPICS time/boot server.
> So we do
> NTPTime_Shutdown
> immediately before iocInit.
> On the vxWorks console, we can see that the NTP thread is indeed off:
> generalTimeReport 1
> Backwards time errors prevented 0 times.
> Current Time Providers:
> "NTP", priority = 100
> Current Time not available
> "OS Clock", priority = 999
> Current Time is 2008-12-30 10:31:48.890000.
> Event Time Providers:
> No Providers registered.
> value = 0 = 0x0
> Please note: the OS Clock does show the correct local time (US CST).
> But on a host machine, if we start a monitor process like "camonitor ..."
> we always get the time off by 6 hours. It seems EPICS takes the CST time
> as the GMT time, then convert it back to CST.
> We tried both
> putenv("TIMEZONE=...
> They did not help.
> Please advice.
> Thanks much and best regards,
> Dehong
- RE: Timezone setting with R3.14.10 Thompson, David H.
RE: EDM Horizontal Bar Szalata, Zenon M.
Re: How to implement simple control algorithm (one more question) Andrew Johnson
<2009>
<2009>
