g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: Re: How to implement simple control algorithm (one more question)
To: tech-talk@aps.anl.gov
Cc: "Ilya V. Kitaev" <mbg033@googlemail.com>
Date: Mon, 5 Jan 2009 11:13:35 -0600
On Sunday 28 December 2008 09:02:47 Dalesio, Leo wrote:
> YOu can make the strings as long as you like. You just can't set or get
> them through channel access then - a 40 character limit. I'm not sure that
> it handles this properly. Jeff or someone else should comment on that. Bob
The 40 character length of the dbr_string_t type that CA uses causes that
limitation.
As to modifying the length of the CALC/OCAL fields of a calc or calcout
record, if you do that make sure that you also modify the corresponding
RPCL/ORPC fields to match, or when an expression longer than 40 characters
gets coverted to postfix tokens it could overwrite memory belonging to some
other field or record.  In recent versions of Base the size needed is
calculated by the macro INFIX_TO_POSTFIX_SIZE() so all you have to give it is
the size of the infix string.
- Andrew
> -----Original Message-----
> From: tech-talk-bounces@aps.anl.gov on behalf of Ilya V. Kitaev
> Sent: Fri 12/5/2008 3:29 AM
> To: Kalantari Babak
> Cc: tech-talk@aps.anl.gov
> Hi,
> Thank you for your answer.
> I'd like to ask one more question:
> Is it ok to break 40 chars limit in CALC field( or another text fields
> like DESC) ?
> I've changed this limit  to 200 in calcoutRecord.dbd, db_access.c and
> epicsTypes.h (MAX_STRING_SIZE define) and it works ok.
> 2008/12/3, Kalantari Babak <BABAK.KALANTARI@psi.ch>:
> > Hi,
> > You do not need to write your own CA application for that.
> > Monitor alarm status of your "ai" with a "calcout" record and write to
> > your "bo" upon occurrence of the conditions.
> > This can be done for example as the following:
> > record(calcout, "$(ALGORITHM)")
> >         field(INPA,"$(YOUR_AI_REC).STAT CP") # monitoring
> >         field(INPB,"$(YOUR_BO_REC).VAL NPP")
> >         field(CALC, "A=3?1:A=5?0:B")
> >         field(OOPT, "On Change")
> >         field(OUT,"$(YOUR_BO_REC) PP")
> > Alarm status value for HIHI is 3 and for LOLO is 5.
> > HTH,
> > Babak
The best FOSS code is written to be read by other humans -- Harold Welte
Prev: Re: RE: Timezone setting with R3.14.10 Dehong Zhang
Next: Re: Problems with Base 3.14.10. and Sequencer 2.0.12 on Cygwin? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Prev: RE: EDM Horizontal Bar Szalata, Zenon M.
Next: RE: How to implement simple control algorithm (one more question) Jeff Hill
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
