Subject: Question on signals with Linux
To: <[email protected]>, <[email protected]>
Date: Mon, 15 Dec 2008 15:56:59 -0600
Folks,
I am trying to write a driver for the Prosilica Gigabit Ethernet cameras under Linux.  They provide a pre-built library for controlling their cameras.  One of the notes for this library says the following:
* As the API use some signals internally, it is required to "protect" some of your system calls (such as sem_wait)  from been interupted. This can be done by calling the system call from within a loop and only exiting from it if there was no error or if errno is different from EINTR.
When I run an EPICS application that calls this library it crashes and this is the output of gdb:
(gdb) bt
#0  0x0808ce33 in SIGAction ()
#1  0x0821bf4d in ignoreSigAlarm (signal=14) at ../../../src/libCom/osi/os/posix/osdSignal.cpp:109
#2  <signal handler called>
#3  0x00110416 in __kernel_vsyscall ()
#4  0x002ce671 in select () from /lib/libc.so.6
#5  0x0808d21e in pPvMultiplexer::Body ()
#6  0x08090e00 in _ThreadFunction ()
#7  0x003b932f in start_thread () from /lib/libpthread.so.0
#8  0x002d620e in clone () from /lib/libc.so.6
The same application works fine under Windows, linked with a Prosilica DLL that uses the identical API to their Linux library.
Does anyone have ideas on how to fix this?
Re: Question on signals with Linux Andrew Johnson
Prev: Problems getting edm functional on NetBSD David Dudley
Next: Re: Question on signals with Linux Andrew Johnson
Prev: Re: Problems getting edm functional on NetBSD David Dudley
