Narrowing down the problems, and now time to bring in more people.
I'm having problems using channel access in edm under NetBSD. I've got everything ported and operational, and edm itself functions correctly. I can install all the libraries except for two, those being epicsPv.so and logPv.so. When I try to load these two libraries, I get an error message about not being able to find 'nss_dns.so.0'.
Now, I wouldn't concern anyone with this problem normally, after all, NetBSD is not a supported architecture. However, the problem is coming from trying to load the channel access library into the program, not from a problem with edm.
The exact function call that looks like it's failing is gethostbyname, and I'm just wondering if there are some tricks done in Epics to get access to that function.
David
On Tue, Dec 16, 2008 at 11:47 AM, David Dudley <[email protected]> wrote:
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
