Subject: Support for shell variables in the EPICS build system
To: tech-talk <[email protected]>
Cc: "Ernest L. Williams Jr." <[email protected]>
Date: Tue, 09 Dec 2008 09:30:18 -0800
I would like to add support for shell variables in convertRelease.pl
(see example patch bellow that is against R3.14.9).
I have been told that this issue was already raised some time ago but
nothing was changed. Looking at the archives I found a post from Ralph
Lange on Tue, 27 May 2003 titled "Re: convertRelease.pl" which makes a
good case against using shell variables.
But in my opinion Ralph makes a case about why some of us should not use
shell variables, not why no one should be able to ... I totally agree
that using shell variables in a production environment can be dangerous
and is in my mind not worth it, but in a development environment it can
be extremely powerful (for example to find out at which version of base
an IOC can work with).
I am sorry if I am re-opening an already closed issue, but I believe
that supporting shell variables, while not for every project could
greatly help some of us.
Remi
--- base/3.14.9/configure/tools/convertRelease.pl	27 Sep 2007 05:49:06 -0000	1.1.1.1
+++ base/3.14.9/configure/tools/convertRelease.pl	13 Nov 2008 02:01:39 -0000
@@ -133,17 +133,22 @@
 	# Expand all already-defined macros in the line:
 	while (my ($pre,$var,$post) = /(.*)\$\((\w+)\)(.*)/) {
-	    last unless (exists $Rmacros->{$var});
-	    $_ = $pre . $Rmacros->{$var} . $post;
+            if (exists $Rmacros->{$var}) {
+                $_ = $pre . $Rmacros->{$var} . $post;
+            } elsif (exists $ENV{$var}) {
+                $_ = $pre . $ENV{$var} . $post;
+            } else {
+                last
 	# Handle "<macro> = <path>"
 	my ($macro, $path) = /^\s*(\w+)\s*=\s*(.*)/;
 	if ($macro ne "") {
-		$macro="TOP" if $macro =~ /^INSTALL_LOCATION/ ;
 		if (exists $Rmacros->{$macro}) {
 			delete $Rmacros->{$macro};
 		} else {
+			push @$Rapps, "TOP" if $macro =~ /^INSTALL_LOCATION/ ;
 			push @$Rapps, $macro;
 	    $Rmacros->{$macro} = $path;
Re: Support for shell variables in the EPICS build system Andrew Johnson
Prev: Re: DeltaTau UMAC ethernet access? Dirk Zimoch
Next: Re: Support for shell variables in the EPICS build system Andrew Johnson
