Subject: Re: Working with sequencer
To: [email protected]
Date: Fri, 21 Nov 2008 09:33:21 +0100
On Thursday 20 November 2008 22:04, David Dudley wrote:
> I've run into a little 'problem' I haven't been able to figure out yet.
> I'm building an IOC that will have a sequencer program in it.
> I've been trying to get the *.stt program to compile automatically as a
> part of the build.
> Problem is that I'm unclear as to how to configure for this.
> 1. I installed base  in /usr/local/EPICS
> 2. The source for base (3.14.9) is in /usr/local/EPICSSRC/base
> 3. Sequencer (2.0.11) is uncompressed into
> /usr/local/EPICSSRC/modules/soft/seq
> 4. I've set INSTALL and INSTALL_APP to install everything in
> /usr/local/EPICS
> Now, I'm working on the RELEASE file in my application.
> According to the documentation I set SNCSEQ to the directory where you
> installed the sequencer.
>    Is that where the executables are, or where I unpacked the source
> into?
Where the executables are, but minus the bin/$(T_A) subdirectory. In other
words, to the $(INSTALL_LOCATION) of the sequencer (which defaults to the
source top-level directory).
> It looks like I need to pull in the RULES_BUILD file from the sequencer
> directory, but how do I do that without accessing the source copy?
No need to do that, there is special code in teh EPICS base rules to include
relevant stuff under $(SNCSEQ)/configure. Typically all you need is to add
<lib-or-exe-name>_SRCS += my-state-machine.st
'makeBaseApp.pl -t example' will give you an example setup and it includes a
state machine.
Cheers
Ben
"Programming = Mathematics + Murphy's Law" (E.W.Dijkstra)
Any text below this line has automatically been added by the
mail server and does not necessarily represent my personal opinion.
Helmholtz-Zentrum Berlin fÃr Materialien und Energie GmbH
Glienicker StraÃe 100, 14109 Berlin
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertretende Vorsitzende: Dr. Jutta Koch-Unterseher
GeschÃftsfÃhrer: Prof. Dr. Anke Rita Pyzalla, Prof. Dr. Michael Steiner, Dr. Ulrich Breuer
Sitz der Gesellschaft: Berlin Handelsregister: AG Charlottenburg, 89 HRB 5583
Information:
Durch die Fusion mit dem ehemaligen Hahn-Meitner-Institut (HMI) ist BESSY nun Teil des neuen Helmholtz-Zentrum Berlin fÃr Materialien und Energie (HZB). Die Fusion wird im Januar 2009 vollzogen sein.
By the merger with the former Hahn-Meitner-Institut (HMI), BESSY became part of the new Helmholtz-Zentrum Berlin fÃr Materialien und Energie (HZB). The merger will be completed by January 2009.
Disclaimer automatically attached by the E-Mail Security Appliance mail0.bessy.de 11/21/08 at Helmholtz-Zentrum Berlin GmbH.
Working with sequencer David Dudley
Prev: Re: archiveviewer - Error in data header Kasemir, Kay
Next: Re: SNL compiler bug (and a fix) Andrew Johnson
Prev: Working with sequencer David Dudley
Next: Re: Working with sequencer Benjamin Franksen
