Subject: Working with sequencer
To: tech-talk <[email protected]>
Date: Thu, 20 Nov 2008 15:04:20 -0600
I've run into a little 'problem' I haven't been able to figure out yet.
I'm building an IOC that will have a sequencer program in it.
I've been trying to get the *.stt program to compile automatically as a part of the build.
Problem is that I'm unclear as to how to configure for this.
1. I installed base  in /usr/local/EPICS
2. The source for base (3.14.9) is in /usr/local/EPICSSRC/base
3. Sequencer (2.0.11) is uncompressed into /usr/local/EPICSSRC/modules/soft/seq
4. I've set INSTALL and INSTALL_APP to install everything in /usr/local/EPICS
Now, I'm working on the RELEASE file in my application.
According to the documentation I set SNCSEQ to the directory where you installed the sequencer.
   Is that where the executables are, or where I unpacked the source into?
It looks like I need to pull in the RULES_BUILD file from the sequencer directory, but how do I do that without accessing the source copy?
David Dudley
Re: Working with sequencer Benjamin Franksen
Prev: archiveviewer - Error in data header Devin Bougie
Next: Re: archiveviewer - Error in data header Kasemir, Kay
Prev: Re: archiveviewer - Error in data header Kasemir, Kay
Next: Re: Working with sequencer Benjamin Franksen
