Subject: |
Re: USE of CA lib: problem using ca_array_put_callback with strings |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 14 Nov 2008 10:04:49 -0600 |
Hi Christophe,
On Friday 14 November 2008 08:01:43 haquin wrote:
> I have some problems with the Channel Access library use,
> more precisely the use of /*ca_array_put_callback*/ with STRINGS !
> We are using a peace of exemple C code, picked-up at :
> *http://lansce.lanl.gov/EPICSdata/ca/client*, that uses this CA API.
> We have some problems with the ca_array_put_callback when we want to
> write strings.
That URL doesn't work any more, can you post at least an extract of the code
that you're using, showing both the call to ca_array_put_callback() and your
callback routine.
> We use this code to put a string in the DESC field of a record,
> The problem is that only the first caracter of the string is written to
> the PV,
> The callback is called, everything seem to bee correct except that there
> is only the first caracter in the destination.
I'm not able to recreate the problem on R3.14.10, so it may be a bug in the
code you're using (I'm not suggesting that you need to upgrade though, since
I'm not aware of any bug fixes in that area of the code). The caput program
that comes with base has a -c option that means 'use put callback' and can
deal with arrays. Here's how I tested it:
tux% bin/linux-x86_64/caput -c anjHost:aiExample.DESC "New string"
Old : anjHost:aiExample.DESC Analog input
New : anjHost:aiExample.DESC New string
tux% bin/linux-x86_64/caput -c -s -a anjHost:aiExample.DESC 1 "Array string"
Old : anjHost:aiExample.DESC New string
New : anjHost:aiExample.DESC Array string
Note that the DESC field will only accept a 1-item array; if you try to send
more it will fail, demonstrating that caput is doing an array put:
tux% bin/linux-x86_64/caput -c -s -a anjHost:aiExample.DESC 2 String array
Old : anjHost:aiExample.DESC Array string
Write callback operation timed out
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
- USE of CA lib: problem using ca_array_put_callback with strings haquin
<2008>
<2008>
