Hi all, I have some problems with the Channel Access library use, more precisely the use of /*ca_array_put_callback*/ with STRINGS ! We are using a peace of exemple C code, picked-up at : *http://lansce.lanl.gov/EPICSdata/ca/client*, that uses this CA API. We have some problems with the ca_array_put_callback when we want to write strings. We use this code to put a string in the DESC field of a record, The problem is that only the first caracter of the string is written to the PV, The callback is called, everything seem to bee correct except that there is only the first caracter in the destination. The /*ca_array_put_callback*/ works fine with other type of data The /*ca_array_put*/ works fine with all type of data we use the 3.14.9 release. Thanx for your help. begin:vcard fn:Christophe Haquin n:Haquin;Christophe email;internet:[email protected] tel;work:02 31 45 46 61 x-mozilla-html:FALSE version:2.1 end:vcard
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
