Subject: Re: Re: question about ca gateway
To: "Dirk Zimoch" <[email protected]>
Date: Thu, 13 Nov 2008 09:58:07 +0800
Hi, Dirk zimoch
     just as you said, I start the ca gateway like this:
#!/bin/bash
export EPICS_CA_ADDR_LIST="10.30.1.165:5064 10.30.1.166:5066 ..."(set the environment variable)
export EPICS_CA_AUTO_ADDR_LIST=NO
gateway -sip 10.30.50.1 -sport 6006 -pvlist /root/GATEWAY.pvlist -access /root/private01.access -log logfile.txt
with  -sip 10.30.50.1 and  -sport 6006  option, so the user set the EPICS_CA_ADDR_LIST="10.30.50.1:6006",and    they didn't set the EPICS_CAS_BEACON_LIST, so if they start an ioc,the ioc will send the udp package to the gateway's port which cause the question occurs.(they use base 3.14.9 to compile ioc) ,you mean if I compiled the ca gateway use base 3.14.10 the question will not occurs? I will try it immediately .
 Thank for you help,
      Best Regards.
     wantianmin
Re: question about ca gateway Dirk Zimoch
Prev: Re: WireSet missing with 3.14.10 Andrew Johnson
Next: Re: question about ca gateway Dirk Zimoch
Prev: Re: question about ca gateway Dirk Zimoch
