Hello Wantianmin,
Instead of setting EPICS_CA_ADDR_LIST and EPICS_CA_AUTO_ADDR_LIST before
starting the gateway, you can use -cip
gateway -sip 10.30.50.1 -sport 6006 -cip "10.30.1.165:5064 10.30.1.166:5066 ..."
-pvlist /root/GATEWAY.pvlist -access /root/private01.access -log logfile.txt
By the way, I do not consider the gateway safe enough to run with root
privileges. (I just guessed that from the /root/ directories you use.) Better
create a gateway user and use -uid.
For the ioc use:
EPICS_CA_ADDR_LIST=10.30.50.1
EPICS_CA_SERVER_PORT=6006
In opposite to EPICS_CA_ADDR_LIST="10.30.50.1:6006", this does not overwrite the
beacon port.
Dirk
万天敏 wrote:
> Hi, Dirk zimoch
> just as you said, I start the ca gateway like this:
> #!/bin/bash
> export EPICS_CA_ADDR_LIST="10.30.1.165:5064 10.30.1.166:5066 ..."(set the environment variable)
> export EPICS_CA_AUTO_ADDR_LIST=NO
> gateway -sip 10.30.50.1 -sport 6006 -pvlist /root/GATEWAY.pvlist -access /root/private01.access -log logfile.txt
> with -sip 10.30.50.1 and -sport 6006 option, so the user set the EPICS_CA_ADDR_LIST="10.30.50.1:6006",and they didn't set the EPICS_CAS_BEACON_LIST, so if they start an ioc,the ioc will send the udp package to the gateway's port which cause the question occurs.(they use base 3.14.9 to compile ioc) ,you mean if I compiled the ca gateway use base 3.14.10 the question will not occurs? I will try it immediately .
> Thank for you help,
> Best Regards.
> wantianmin
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Re: Re: question about ca gateway, 万天敏
- Re: Re: question about ca gateway 万天敏
Re: WireSet missing with 3.14.10 Dehong Zhang
<2008>
<2008>
