Subject: Re: IOC to use time from its own processor
Cc: [email protected]
Date: Thu, 06 Nov 2008 14:08:05 -0600
Hi Andrew,
Sorry to bother you so much!
Since i don't have an event, shall I remove the "if" statement?
Thanks much and best regards,
Dehong
----- Original Message -----
Date: Thursday, November 6, 2008 2:04 pm
To: Dehong Zhang <[email protected]>
> On Thursday 06 November 2008 13:51:26 Dehong Zhang wrote:
> > Thanks much.  Now I get a lot of:
> > ... recGblGetTimeStamp failed
> > It seems the recGblGetTimeStamp method is trying to check
> > the timestamp event, which we don't have.
> Ah, I forgot that recGblGetTimeStamp() uses the getEvent() routine
> with an
> event number of 0 to get record timestamps.  On R3.14.8 you need to
> provide
> and register getEvent() routine as well (instead of the NULL second
> argument
> to iocClockRegister()).  The code should look like this:
> int clockGetEvent (epicsTimeStamp *pDest, int event)
>     if (event == epicsTimeEventCurrentTime) {
>         return clockGetCurrent (pDest);
>     return -1;
> - Andrew
> Talk is cheap. Show me the code. -- Linus Torvalds
Re: IOC to use time from its own processor Andrew Johnson
IOC to use time from its own processor Dehong Zhang
Re: IOC to use time from its own processor Dehong Zhang
Prev: Re: IOC to use time from its own processor Andrew Johnson
Next: Re: IOC to use time from its own processor Andrew Johnson
