Subject: Re: IOC to use time from its own processor
To: Dehong Zhang <[email protected]>
Cc: [email protected]
Date: Thu, 6 Nov 2008 14:03:35 -0600
On Thursday 06 November 2008 13:51:26 Dehong Zhang wrote:
> Thanks much.  Now I get a lot of:
> ... recGblGetTimeStamp failed
> It seems the recGblGetTimeStamp method is trying to check
> the timestamp event, which we don't have.
Ah, I forgot that recGblGetTimeStamp() uses the getEvent() routine with an
event number of 0 to get record timestamps.  On R3.14.8 you need to provide
and register getEvent() routine as well (instead of the NULL second argument
to iocClockRegister()).  The code should look like this:
int clockGetEvent (epicsTimeStamp *pDest, int event)
    if (event == epicsTimeEventCurrentTime) {
        return clockGetCurrent (pDest);
    return -1;
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: IOC to use time from its own processor Dehong Zhang
Re: IOC to use time from its own processor Andrew Johnson
Prev: Re: IOC to use time from its own processor Dehong Zhang
Next: Re: IOC to use time from its own processor Dehong Zhang
