Subject: Re: Process 'bo' on write?
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Tue, 07 Oct 2008 18:11:37 +0200
Hi David,
Use 2 bo records. One for the user to write to and a second that writes to the hardware. The second one monitors the first one with a CP DOL link.
Dirk
David Dudley wrote:
Is there a way for me to set a bo (or ao) record so that it only
processes when it's value is changed?
I've got a number of those records that I only need written to the PLC
when the value is changed.
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Process 'bo' on write? David Dudley
Prev: ScaNET : is CA Server for DOTNET a possibility ? Mogamat Amien Crombie
Next: Re: Process 'bo' on write? David Dudley
Prev: Re: Process 'bo' on write? Andrew Johnson
Next: RE: Process 'bo' on write? Elder Matias
