Hi Lewis,
On Thursday 02 October 2008 10:56:11 J. Lewis Muir wrote:
> On 9/29/08 6:38 PM, Andrew Johnson wrote:
> A few comments.
> Platform: darwin-x86 (Mac OS X 10.5.5); gcc 4.0.1
> 1. I noticed the distribution contains .cvsignore files. These can
> trivially be removed before packaging on a modern UNIX environment with
> something like:
> $ find . -name '.cvsignore' -print0 | xargs -0 rm
We leave the .cvsignore files in the distribution because many sites (APS
included) actually re-import the base tarfile into a local CVS repository to
manage local changes, hence the .cvsignore files are still useful.
> 2. I get various compiler warnings when building. This is not new, but
> if you want to see them, search for "warning" in my build log at
> http://www.imca.aps.anl.gov/~jlmuir/epics-3.14.10-build.txt
I've been working on reducing the number of warnings and on some platforms I
actually get none at all now, but with more recent versions of gcc there are
huge numbers from src/gdd which we're not touching because GDD is going to be
going away someday. Other warnings are from code generated by flex and/or
antelope, which we didn't write and are not programs I want to look inside if
I don't have to.
> 3. The host platforms list in the README at
> http://www.aps.anl.gov/epics/base/R3-14/10-docs/README.html
> does not match the list in configure/CONFIG_SITE. For example,
> darwin-x86 and others are not listed in the README.
Noted,
> 4. I was hoping for an easy way to run all tests for my platform (such
> as "make test" from the EPICS base root directory), but I couldn't find
> it.
> Is there a better way?
As you already discovered, "make runtests".
> The macEnvExpandTest test prints error messages, but
> maybe that's normal?
Yes, that's expected; if you run the test manually it tells you how many error
messages you should have got, but for some reason that number doesn't agree
with my output right now...
> 5. It would be nice if the EPICS Application Developer's Guide used
> links (hyper-references?) in the table of contents.
I agree...
> It looks like you're using Adobe FrameMaker 6.0 to create the
> Application Developer's Guide. Does FrameMaker support making the table
> of contents with links like this?
Correct, the AppDevGuide is in FrameMaker 6. It certainly manages to create
hyperlinks in the index, let's see... <rummage, RTFM, RTOFM; Ooh, what does
this check-box do? Hmm, doesn't work, why not? Now it does, what's going
on? Ahh, there's an invisible delay, just be patient and use ls -l...>.
Ok, I just installed a new version of the R3.14.10 AppDevGuide where the TOC
has hyperlinks in it; thanks for the suggestion!
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: Base R3.14.10-RC1 Released Benjamin Franksen
- Base R3.14.10-RC1 Released Andrew Johnson
- Re: Base R3.14.10-RC1 Released J. Lewis Muir
Re: devStats - OSI version of devVxStats Phillip Sorensen
Re: devStats - OSI version of devVxStats Andrew Johnson
<2008>
<2008>
