Subject: Re: EPICS perl tools in 3.14.10-pre1
To: [email protected]
Date: Tue, 23 Sep 2008 14:41:23 -0500
Hi Stefan,
On Tuesday 23 September 2008 11:18:04 Stefan Heim wrote:
> The trick is to rely on the relative location of the perl module
> directory with respect to the HOST_BIN directory rather than on absolute
> paths. Lines of the form
> use lib '@TOP@/lib/perl';
> have to be replaced by
> use FindBin qw($Bin);
> use lib "$Bin/../../lib/perl";
> in the *.pl@ tools in order to have the tools work independently of the
> absolute path of EPICS_BASE. An analogous modification does the job for
> the new CA.pm.
> I'd love to see this change (patch attached) checked into CVS before the
> 3.14.10 release. Any comments?
I like it, and actually I'll go further than you because none of the scripts
in base need to have @TOP@ expanded at all.  This simplifies expandVars.pl
which no longer needs to have the special bootstrap, but I think we still
need to include it so we can provide a way for scripts outside of base to add
the path @EPICS_BASE@/lib/perl to their @INC list.
Thanks, I will add this approach before R3.14.10 comes out.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
EPICS perl tools in 3.14.10-pre1 Stefan Heim
Prev: javaIOC Marty Kraimer
Next: Re: StreamDevice 2.4 released Dirk Zimoch
Prev: EPICS perl tools in 3.14.10-pre1 Stefan Heim
Next: EPICS interface to Agilent Oscilloscope Dach Miroslaw
