EPICS base release 3.14.10-pre1 added support for the installation of
perl modules to the build system. In an approach to modularize the perl
tools used by the build system (convertRelease.pl et al., formerly
residing under configure/tools, now found in src/tools), some common
functionality has been factored out into modules (Copy.pm, Getopts.pm,
Path.pm and Release.pm so far) and is used in the tools by means of
directives similar to
use lib '@TOP@/lib/perl';
use EPICS::Release;
The first directive is necessary to expand perl's @INC array with the
location where the EPICS perl modules reside; the @TOP@ pattern in that
directive is replaced by the new variable expansion facility during
installation and is set to the value of INSTALL_LOCATION from
CONFIG_SITE via the EXPANDFLAGS in RULES_EXPAND.
Unfortunately, this absolute path breaks builds of EPICS base inside
clean chroot environments (used e.g. when building Debian packages),
because with these kind of builds INSTALL_LOCATION is not a valid path
anymore when the EPICS perl tools are actually run later from a
different path. Similar problems should arise when an EPICS base is NFS
mounted on client machines to a different location than during build.
After spending some time trying to resolve this situation with ugly and
uglier hacks, I've finally found a solution that
1) works during the bootstrapping, i.e. when fullPathName.pl et al. are
used during the EPICS build itself.
2) works afterwards, i.e. when the tools are used after the installation
of the EPICS base package, possibly with a different path to
EPICS_BASE than at build time.
The trick is to rely on the relative location of the perl module
directory with respect to the HOST_BIN directory rather than on absolute
paths. Lines of the form
have to be replaced by
use FindBin qw($Bin);
use lib "$Bin/../../lib/perl";
in the *.pl@ tools in order to have the tools work independently of the
absolute path of EPICS_BASE. An analogous modification does the job for
the new CA.pm.
I'd love to see this change (patch attached) checked into CVS before the
3.14.10 release. Any comments?
-Stefan
Stefan Heim <[email protected]>
X-ray microscopy scientist, BESSY, Berlin
diff -Nur epics-base-3.14.10~pre1.orig/src/cap5/caget.pl@ epics-base-3.14.10~pre1/src/cap5/caget.pl@
--- epics-base-3.14.10~pre1.orig/src/cap5/caget.pl@ 2008-06-28 00:19:23.000000000 +0200
+++ epics-base-3.14.10~pre1/src/cap5/caget.pl@ 2008-09-23 17:37:07.000000000 +0200
@@ -1,7 +1,8 @@
#!/usr/bin/perl
use strict;
-use lib '@TOP@/lib/perl';
+use FindBin qw($Bin);
+use lib "$Bin/../../lib/perl";
use Getopt::Std;
use CA;
diff -Nur epics-base-3.14.10~pre1.orig/src/cap5/cainfo.pl@ epics-base-3.14.10~pre1/src/cap5/cainfo.pl@
--- epics-base-3.14.10~pre1.orig/src/cap5/cainfo.pl@ 2008-06-28 00:19:24.000000000 +0200
+++ epics-base-3.14.10~pre1/src/cap5/cainfo.pl@ 2008-09-23 17:37:07.000000000 +0200
@@ -1,7 +1,8 @@
#!/usr/bin/perl
use strict;
use Getopt::Std;
use CA;
diff -Nur epics-base-3.14.10~pre1.orig/src/cap5/camonitor.pl@ epics-base-3.14.10~pre1/src/cap5/camonitor.pl@
--- epics-base-3.14.10~pre1.orig/src/cap5/camonitor.pl@ 2008-06-28 00:19:24.000000000 +0200
+++ epics-base-3.14.10~pre1/src/cap5/camonitor.pl@ 2008-09-23 17:37:07.000000000 +0200
@@ -1,7 +1,8 @@
#!/usr/bin/perl
use strict;
use Getopt::Std;
use CA;
diff -Nur epics-base-3.14.10~pre1.orig/src/cap5/CA.pm@ epics-base-3.14.10~pre1/src/cap5/CA.pm@
--- epics-base-3.14.10~pre1.orig/src/cap5/CA.pm@ 2008-06-28 00:19:21.000000000 +0200
+++ epics-base-3.14.10~pre1/src/cap5/CA.pm@ 2008-09-23 17:37:07.000000000 +0200
@@ -29,7 +29,8 @@
require DynaLoader;
# Add our lib/<arch> directory to the library search path
-push @DynaLoader::dl_library_path, '@TOP@/lib/'.$ENV{EPICS_HOST_ARCH};
+push @DynaLoader::dl_library_path, "$Bin/../../lib/".$ENV{EPICS_HOST_ARCH};
bootstrap Cap5 $VERSION;
diff -Nur epics-base-3.14.10~pre1.orig/src/cap5/caput.pl@ epics-base-3.14.10~pre1/src/cap5/caput.pl@
--- epics-base-3.14.10~pre1.orig/src/cap5/caput.pl@ 2008-06-28 00:19:25.000000000 +0200
+++ epics-base-3.14.10~pre1/src/cap5/caput.pl@ 2008-09-23 17:37:07.000000000 +0200
@@ -1,7 +1,8 @@
#!/usr/bin/perl
use strict;
use Getopt::Std;
use CA;
diff -Nur epics-base-3.14.10~pre1.orig/src/tools/convertRelease.pl@ epics-base-3.14.10~pre1/src/tools/convertRelease.pl@
--- epics-base-3.14.10~pre1.orig/src/tools/convertRelease.pl@ 2008-08-30 00:15:00.000000000 +0200
+++ epics-base-3.14.10~pre1/src/tools/convertRelease.pl@ 2008-09-23 17:37:07.000000000 +0200
@@ -15,7 +15,8 @@
use strict;
use Cwd qw(cwd abs_path);
use Getopt::Std;
diff -Nur epics-base-3.14.10~pre1.orig/src/tools/expandVars.pl@ epics-base-3.14.10~pre1/src/tools/expandVars.pl@
--- epics-base-3.14.10~pre1.orig/src/tools/expandVars.pl@ 2008-04-03 23:57:10.000000000 +0200
+++ epics-base-3.14.10~pre1/src/tools/expandVars.pl@ 2008-09-23 17:40:01.000000000 +0200
@@ -9,11 +9,12 @@
# expandVars.pl@,v 1.1.2.4 2008/04/03 21:57:10 anj Exp
BEGIN {
# Do not copy this BEGIN code for other tools,
# it's only needed so expandVars can bootstrap itself.
- our $libperl = '@TOP@/lib/perl';
- $libperl = '..' if ($libperl =~ m/^[@]TOP[@]/);
+ our $libperl = "$Bin/../../lib/perl";
+ $libperl = '..' if ($libperl =~ m#/src/tools/\.\./\.\./lib/perl#);
use lib $libperl;
diff -Nur epics-base-3.14.10~pre1.orig/src/tools/fullPathName.pl@ epics-base-3.14.10~pre1/src/tools/fullPathName.pl@
--- epics-base-3.14.10~pre1.orig/src/tools/fullPathName.pl@ 2008-04-03 23:57:11.000000000 +0200
+++ epics-base-3.14.10~pre1/src/tools/fullPathName.pl@ 2008-09-23 17:37:07.000000000 +0200
@@ -15,7 +15,8 @@
use strict;
use EPICS::Path;
print AbsPath(shift), "\n";
- Re: EPICS perl tools in 3.14.10-pre1 Andrew Johnson
Re: StreamDevice 2.4 released Rod Nussbaumer
RE: ASYN R4.10 Release Rees, NP (Nick)
<2008>
Re: CA gateway and CA beacons Dirk Zimoch
<2008>
