Subject: Re: About Runnig of epics
To: Selim Ünal <[email protected]>
Cc: [email protected]
Date: Tue, 09 Sep 2008 10:41:02 +0200
Hi Selim,
The "unknown" architecture is a hint that EPICS_HOST_ARCH is not set. I think that should have been done in ./setup.sh. How did you use this file?
Wrong:  ./setup.sh
Correct: . ./setup.sh
In order to set environment variables in your current shell, you have to _source_ the setup file, not to _call_ it.
Dirk
Selim Ünal wrote:
I installed the epics in system of linux(debian) with command of ./setup.sh .Then , I write " startIoc.sh " or "startMedm.sh" , I dont start epics. Could you help me? It give error that is "Virtual Linac doesn't support this architecture:Linux unknown"
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
About Runnig of epics Selim Ünal
Prev: Re: EPICS base and/or EDM with debugging info Andrew Johnson
Next: Re: About Runnig of epics Dirk Zimoch
Prev: About Runnig of epics Selim Ünal
