Subject: Re: How to use the output array of a waveform record ?
To: haquin <[email protected]>
Cc: [email protected]
Date: Tue, 08 Jul 2008 11:29:05 -0400
haquin wrote:
Can someone tell me how to specify that the :
- INPA of the sub record is linked to the first element of the waveform array
- INPB of the sub record is linked to the second element of the waveform array
- INPK of the sub record is linked to the 11th element of the waveform array
You will need to use a subArray record to pull out the individual elements of your waveform to use in your subroutine record. Alternately, you can use a genSub record rather then a sub record and access the elements from within the routine.
Steven Hartman
[email protected] || 865-574-3242
Re: How to use the output array of a waveform record ? haquin
Prev: Re: EPICS meeting in Padua Eric Bjorklund
Next: RE: EPICS meeting in Padua Dalesio, Leo
Prev: How to use the output array of a waveform record ? haquin
Next: Re: How to use the output array of a waveform record ? haquin
