Subject: Re: How to use the output array of a waveform record ?
To: "Steven M. Hartman" <[email protected]>
Cc: [email protected]
Date: Wed, 09 Jul 2008 08:33:18 +0200
Steven M. Hartman a écrit :
You will need to use a subArray record to pull out the individual elements of your waveform to use in your subroutine record. Alternately, you can use a genSub record rather then a sub record and access the elements from within the routine.
Steve,
Does this mean that I have to use one subArray record for each individual element of my waveform ?
if not, my question remains ...
How to specify that the :
- INPA of the sub record is linked to the first element of the subArray array
- INPB of the sub record is linked to the second element of the subArray array
- INPK of the sub record is linked to the 11th element of the subArray array
I understand If I use a genSub record, I will be able to access the elements from within the routine,
but is it possible to output them to other records ?
Thanks fot your help
How to use the output array of a waveform record ? haquin
Re: How to use the output array of a waveform record ? Steven M. Hartman
Prev: Re: Ethernet-to-RS232 Mauro Giacchini
Next: RE: Ethernet-to-RS232 Rees, NP (Nick)
Prev: Re: How to use the output array of a waveform record ? Steven M. Hartman
Next: EPICS meeting in Padua Dalesio, Leo
