Subject: Re: latest motor record on RTEMS?
To: [email protected]
Date: Wed, 25 Jun 2008 14:10:49 -0400
I think I'm OK for now. I merged some code from the 5.3 drvOms58.cc (that Kate had modified for RTEMS) into the 6.1 distribution. Everything seems to run OK now on my test setup. It will be good when Kate's mods are merged into the main distribution. Thanks to all who responded to my post.
Mark Rivers wrote:
It would be good to get the RTEMS modifications merged into the main distribution. Kate, can you send them to Ron?
Sent: Tue 6/24/2008 8:25 PM
To: John M. Skinner
Cc: [email protected]
John M. Skinner wrote:
The card already runs under RTEMS with motor version 5.3 with Kate's
drvOms58.cc. I think it's a matter of getting her code into the driver
in the new motor record code. I was hoping downloading the latest
would have the oms58 RTEMS support already in it.
I upgraded to R6.1, but it needed modification for RTEMS.
I will send you my version.
Cheers,
Kate
I forgot to mention we're running OMS58 cards.
Have you tried Harvey's suggestion (let the card allow supervisory
VME access)?
Under RTEMS -- by default -- VME access is always 'supervisory'.
-- T.
latest motor record on RTEMS? John M. Skinner
RE: latest motor record on RTEMS? Rarback, Harvey
Re: latest motor record on RTEMS? John M. Skinner
Re: latest motor record on RTEMS? Till Straumann
Re: latest motor record on RTEMS? Kate Feng
RE: latest motor record on RTEMS? Mark Rivers
Prev: Re: EDM Freezing On Linux - MEDM similar problem Rodney R. Porter
Next: Re: latest motor record on RTEMS? Kate Feng
Prev: RE: latest motor record on RTEMS? Mark Rivers
