This has been on our wish list for some time too. Just being able to
identify which soft IOC a PV, or a PV collision, is coming from would be
very useful.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Jeff Hill
Sent: Monday, April 28, 2008 7:29 PM
To: 'Allison, Stephanie'; 'EPICS Tech-Talk'
Subject: RE: Multiple IOCs on the same Host - question on dynamically
allocatedTCP Ports
Hello Stephanie,
The specific of how this gets configured would need to be worked out,
but
this does appear to be a good idea. If you would like I could add your
request as a Mantis entry against R3.15 so I have a reminder to look at
this
sometime before R3.15 gets released?
Jeff
> From: [email protected]
> On Behalf Of Allison, Stephanie
> Sent: Monday, April 28, 2008 11:04 AM
> To: EPICS Tech-Talk
> Subject: Multiple IOCs on the same Host - question on dynamically
allocated
> TCP Ports
> Hello,
> When multiple IOCs run on the same host, using the same
> EPICS_CA_SERVER_PORT, they use the same port for UDP channel
connection
> requests but have to use different ports for the CA TCP connection (of
> course). The CA reference manual says:
> "If the CA server library detects that a server is attempting to start
on
> the same port as an existing CA server then both servers will use the
same
> UDP port, and the 2nd server will be allocated an ephemeral TCP port."
> Is there a way to set the allowable range of TCP ports that the IOC is
> allowed to choose from for its TCP port? In particular, on a RHEL4
linux
> server.
> The reason for this is that we wish to have some of our CA clients,
outside
> our firewall, connect directly to IOCs (both RTEMS and linux) inside
the
> firewall. We don't want them to go through a CA proxy gateway process
and
> we don't want to have to set their EPICS_CA_ADDR_LISTs to include
different
> EPICS_CA_SERVER_PORT values. We also don't want to open up our
firewall
to
> all TCP ports just to allow this communication but are willing to
allow a
> small range of predefined TCP ports. And we don't want to combine our
IOCs
> into one. Essentially, we want each soft IOC to use the same
> EPICS_CA_SERVER_PORT for UDP connection requests but a predefined port
for
> the TCP connection (ie, a new environment variable like
> EPICS_CA_SERVER_TCP_PORT which would be set differently in each of our
soft
> IOC startup files).
> Any thoughts? Thank you,
> Stephanie Allison
- Multiple IOCs on the same Host - question on dynamically allocated TCP Ports Allison, Stephanie
- RE: Multiple IOCs on the same Host - question on dynamically allocated TCP Ports Jeff Hill
RE: RTEMS-GeSys_2.1.beta and cexp-1.5 for uC5282 Coldfire Module K.M Ha
RE: procServ V2.1.0 soft IOC server released Thompson, David H.
<2008>
RE: Multiple IOCs on the same Host - question on dynamically allocated TCP Ports Allison, Stephanie
Edm-1-11-1f compilation problem [SEC=UNCLASSIFIED] WANG, Jian
<2008>
