Subject: Re: Archiveviewer - unable to plot values
To: "Duggan, AJ \(Andrew\)" <[email protected]>
Cc: "Tech Talk \(E-mail\)" <[email protected]>
Date: Thu, 24 Apr 2008 06:47:03 -0700
Hi, AJ!
Please, check out this discussion, will you:
http://www.aps.anl.gov/epics/tech-talk/2006/msg00546.php
http://www.aps.anl.gov/epics/tech-talk/2006/msg00547.php
http://www.aps.anl.gov/epics/tech-talk/2006/msg00548.php
http://www.aps.anl.gov/epics/tech-talk/2006/msg00549.php
Sergei
Duggan, AJ (Andrew) wrote:
I'm getting the following message with the archiveviewer application, when a plot is requested.
"java.lang.Exception: Couldn't execute the archiver.values request
  java.io.IOException: org.xml.sax.SAXParseException: expected Element"
There are a couple of other posts on Tech-Talk with this same problem, but no posts that say what the fix was.
Can anyone who's overcome this one let me know the solution please?
I'm running on Scientific Linux, using EPICS 3.14.8.2
I can extract data from the archive files using the Perl interface, so I don't think it's any kind of file corruption.
Andy
Archiveviewer - unable to plot values Duggan, AJ (Andrew)
Prev: Archiveviewer - unable to plot values Duggan, AJ (Andrew)
Next: RE: Archiveviewer - unable to plot values Kasemir, Kay
