Subject: Re: Channel Archiver compiling problem with Xerces XML Library
To: [email protected]
Cc: [email protected]
Date: Mon, 14 Apr 2008 16:46:30 -0400
On Apr 13, 2008, at 05:25 , Tasaddaq Ali Khan wrote:
Dears
I have successfully compiled XML-RPC, Expat, XML Simple and Frontier by following the guideline given in the manul of Channel Archiver. But there are following errors when I tried to compile Xerces XML Library using make command. Can you guide me how to solve the problem?
invalid use of undefined type ‘struct xercesc_2_4::MemoryManager’
Newer compilers (like gcc 3.4.4 for RedHat WS 4, or gcc 4.0 as used on Mac OS 10.4)
need this patch:
Add
   #include <xercesc/framework/MemoryManager.hpp>
to
   src/xercesc/util/RefArrayOf.hpp
-Kay
Channel Archiver compiling problem with Xerces XML Library Tasaddaq Ali Khan
Prev: Re: TVME200 and IP-Octal 232 Martin L. Smith
Next: edm font file Emmanuel Mayssat
Prev: Channel Archiver compiling problem with Xerces XML Library Tasaddaq Ali Khan
Next: can't build R3.13 extension William F. Steele
