Subject: can't build R3.13 extension
To: [email protected]
Date: Mon, 14 Apr 2008 01:24:15 -0700
I tried to follow the instructions in the document "Building EPICS R3.13 extensions with R3.14 base", but the document appears to be out of date. I set the symbol COMPAT_TOOLS_313=YES in base/configure/ CONFIG_SITE as instructed and then tried to do a make in base/config/ tools, but that failed as there is no Makefile there. I looked back to the R3.14.5 release (I'm using R3.14.9) and found that in that release, /config/tools does have a Makefile. I copied it into my R3.14.9 release and then did a make, which worked, but that did not help building the R3.13 extension. The problem is that the struct 'oldChannelNotify' is not defined. Presumably, that's what the compatibility mechanism is supposed to do, but it doesn't seem to work.
W. F. Steele
Re: can't build R3.13 extension Geoff Savage
Prev: Channel Archiver compiling problem with Xerces XML Library Tasaddaq Ali Khan
Next: Re: can't build R3.13 extension Geoff Savage
Prev: Re: Channel Archiver compiling problem with Xerces XML Library Kay-Uwe Kasemir
