Subject: Re: calc record LINK error
To: [email protected]
Date: Tue, 26 Feb 2008 10:29:10 +0100
On Friday 22 February 2008 19:31, Emmanuel Mayssat wrote:
> The first thing I would try is to change the CP flags into a NPP.
> It should work in your case, given the value of your calc's SCAN and the
> fact that all of your records are located in the same IOC.
> The difference between CP and NPP (you may already know that) is that
> you use a channel access link (monitor) or a database link. Those are
> two fundamentally different ways to fetch the value of a PV.
Since the OP used CP flag and not CPP, I would assume that he wants to
process both periodically and on monitor.
Cheers
Ben
"Programming = Mathematics + Murphy's Law" (E.W.Dijkstra)
calc record LINK error Leicester, PJ (Pete)
Re: calc record LINK error Emmanuel Mayssat
Prev: Re: Multiple target os-class application build Andrew Johnson
Next: Re: Initialize multi-element field Benjamin Franksen
Prev: Re: calc record LINK error Emmanuel Mayssat
Next: calc record LINK error Leicester, PJ (Pete)
