Subject: calc record LINK error
To: <[email protected]>
Date: Fri, 22 Feb 2008 13:21:09 -0000
Title: Message
I have a calc record that somehow occasionally goes into link error and seems never to recover when it should. The purpose of the record is to generate a status based on four motor records by picking up the MOVN and SEVR fields.
record(calc, "BL22I-AL-SLITS-02:MOTORSTA") {
  field(SCAN, "1 second")
  field(CALC, "(A|B|C|D)>0?1:0")
  field(INPA, "BL22I-AL-SLITS-02:X:PLUS.MOVN CP MS")
  field(INPB, "BL22I-AL-SLITS-02:X:MINUS.MOVN CP MS")
  field(INPC, "BL22I-AL-SLITS-02:Y:PLUS.MOVN CP MS")
  field(INPD, "BL22I-AL-SLITS-02:Y:MINUS.MOVN CP MS")
  field(ACKT, "NO")
All the records are in a single IOC. When it goes wrong the calc record goes into LINK error and does not recover even when the four motor records appear OK. I tried poking PROC on the calc record but this had no effect. The only way I could get the calc record to start updating correctly again was to either re-write the INPx links or to do a move on the motors so that MOVN changed. I think this behaviour is incorrect in that the calc record should have updated when I sent PROC or at the scan rate? Have I missed something?
For the record we are running 3.14.8.2 on VxWorks.
The calc record status is as follows when its stuck in its LINK error state:-
BL22I-MO-IOC-01 -> dbpr "BL22I-AL-SLITS-02:MOTORSTA",2
A: 0                ACKS: INVALID       ACKT: NO            ADEL: 0
ASG:                B: 0                BKPT: 0x00          C: 0
CALC: (A|B|C|D|E|F|G|H|I|J|K|L)>0?1:0   D: 0                DESC:
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DTYP: <nil>         E: 0                EGU:                EVNT: 0
F: 0                FLNK:CONSTANT 0     G: 0                H: 0
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV: NO_ALARM       HYST: 0             I: 0
INPA:CA_LINK BL22I-AL-SLITS-02:X:PLUS.MOVN CP MS
INPB:CA_LINK BL22I-AL-SLITS-02:X:MINUS.MOVN CP MS
INPC:CA_LINK BL22I-AL-SLITS-02:Y:PLUS.MOVN CP MS
INPD:CA_LINK BL22I-AL-SLITS-02:Y:MINUS.MOVN CP MS           INPE:CONSTANT 0
INPF:CONSTANT 0     INPG:CONSTANT 0     INPH:CONSTANT 0     INPI:CONSTANT 0
INPJ:CONSTANT 0     INPK:CONSTANT 0     INPL:CONSTANT 0     J: 0
K: 0                L: 0                LCNT: 0             LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW: 0              LSV: NO_ALARM
MDEL: 0             NAME: BL22I-AL-SLITS-02:MOTORSTA        NSEV: NO_ALARM
NSTA: NO_ALARM      PACT: 0             PHAS: 0             PINI: NO
PREC: 0             PRIO: LOW           PUTF: 0             RPRO: 0
SCAN: 1 second      SDIS:CONSTANT       SEVR: INVALID       STAT: LINK
TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 0
VAL: 0
value = 0 = 0x0
The input motor records are all OK showing no alarms:-
BL22I-MO-IOC-01 -> dbpr "BL22I-AL-SLITS-02:X:PLUS"
ASG:                ATHM: 1             CDIR: 0             CNEN: Disable
DESC: X Plus Motor  DHLM: 0             DIFF: 0             DISA: 0
DISP: 0             DISV: 1             DLLM: -20.7745      DMOV: 1
DRBV: -15.507       DVAL: -15.507       HLM: 16.607         HLS: 0
LLM: -4.1675        LLS: 0              LVIO: 0             MOVN: 0
NAME: BL22I-AL-SLITS-02:X:PLUS          OFF: 16.607         RBV: 1.1
RDIF: 0             REP: 31011          RHLS: 0             RLLS: 0
RLV: 0              RMP: 31014          RRBV: 31014         RVAL: 31014
SEVR: NO_ALARM      STAT: NO_ALARM      TDIR: 1             TPRO: 0
VAL: 1.1            VERS: 6.222
value = 0 = 0x0
Pete Leicester
Mr P J Leicester
Senior Software Engineer
Diamond Light Source Ltd.
Prev: Problem with soft motor record Rarback, Harvey
Next: Re: TTL output with soft IOC on Linux Emmanuel Mayssat
Prev: Re: calc record LINK error Benjamin Franksen
Next: TTL output with soft IOC on Linux Jiro Fujita
