On Fri, 2008-01-04 at 15:55 +0800, zhangdemin99 wrote:
> Dear all,
> (2)cd /usr/src/kernels/2.6.9-67.EL-i686
> (3)make oldconfig
> (4)make dep
> (5)cd <linux-gpib>
> (6)./configure
> (7)make
> (8)make install
> It also says L0 not found, what should I do next?
Are the gpib driver installed in the kernel module
directory? /lib/modules/<kernel_version>/gpib
Did you load the gpib drivers? ( you have to modprobe something. If your
card is supported by linux-gpib, which drivers should you load?)
Finally you need to configure the modules in /etc/gpib.conf (that is
where you specify the interface name LO)
> GpibBoardDriverConfig("L0",1,0,3,0)
> st.cmd -- Line 18 -- Command GpibBoardDriverConfig not found.
> iocInit()
asyn doesn't include GPIB support by default.
I believe you need to set the LINUX_GPIB to yes in the asyn RELEASE
file. Please refer to the asyn docs.
Cheers,
Emmanuel
- problem in running application of PSM6003 zhangdemin99
RE:problem in running application of PSM6003 zhangdemin99
<2008>
<2008>
