Dear all,
Thanks Norum for your attention, and now it works well.But there is another problem when running appilication which I have built for the NI power supply connected to the PC with PCI-GPIB board.I have built the driver NI-4882 package for the board. In the st.cmd file,I only add GpibBoardDriverConfig("L0",1,0,3,0), but it says this command not found. Is it linux-gpib not built well? I have built linux-gpib like this: (1)cp /boot/config-2.6.9-67.EL /usr/src/kernels/2.6.9-67.EL-i686 (2)cd /usr/src/kernels/2.6.9-67.EL-i686 (3)make oldconfig (4)make dep (5)cd <linux-gpib> (6)./configure (7)make (8)make install It also says L0 not found, what should I do next?
many thanks in advance [fel@localhost ~]$ cd EPICS/psm6003/iocBoot/iocPSM6003
[fel@localhost iocPSM6003]$ ../../bin/linux-x86/PSM6003 st.cmd #!../../bin/linux-x86/PSM6003 ## You may have to change PSM6003 to something else ## everywhere it appears in this file < envPaths epicsEnvSet(ARCH,"linux-x86") epicsEnvSet(IOC,"iocPSM6003") epicsEnvSet(TOP,"/home/fel/EPICS/psm6003") epicsEnvSet(PSM6003,"/home/fel/EPICS/module/psm6003") epicsEnvSet(ASYN,"/home/fel/EPICS/4-6") epicsEnvSet(EPICS_BASE,"/home/fel/EPICS/base") cd /home/fel/EPICS/psm6003 ## Register all support components dbLoadDatabase("dbd/PSM6003.dbd",0,0) PSM6003_registerRecordDeviceDriver(pdbbase) ## Load record instances #dbLoadRecords("db/xxx.db","user=felHost") dbLoadRecords("db/devPSM6003.db","user=felHost") GpibBoardDriverConfig("L0",1,0,3,0) st.cmd -- Line 18 -- Command GpibBoardDriverConfig not found. iocInit() Starting iocInit ############################################################################ ## EPICS R3.14.9- $R3-14-9-pre1$ $2006/11/20 21:09:36$ ## EPICS Base built Dec 30 2007 ############################################################################ 2008/01/04 11:16:54.163 devSupportGpib:getDeviceInstance link 0 L0 failed asynMa nager:connectDevice port L0 not found current-in: init_record : no driver for link 0
2008/01/04 11:16:54.163 devSupportGpib:getDeviceInstance link 0 L0 failed asynMa nager:connectDevice port L0 not found current-out: init_record : no driver for link 0
iocInit: All initialization complete ## Start any sequence programs #seq sncxxx,"user=felHost" The CA server's beacon address list was empty after initialization? epics> Best wishes
deminzhang 网 易 有 道 词 典 -- 全 球 最 强 大 的 免 费 英 汉 互 译 词 典 ( 只 有 2 兆 )
| ANJ, 02 Sep 2010 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
