Since the actual maximum array size that can be sent is the smallest of both the client and server's settings it's possible to set this to a giant number on your client workstations and gateways where you usually have the least idea what to set it to (our Unix shell configuration sets this at the same time as setting EPICS_HOST_ARCH). For each IOC you still have to work out how big your largest array field is and set the value appropriately, but at least this limits the scope of the problem. I know Jeff has plans for removing this limit in the future, but it relies on completely replacing GDD with Data Access, which is a fairly major change. - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
