1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CA wishlist :)
To: EPICS Techtalk <[email protected]>
Date: Wed, 12 Dec 2007 08:23:47 +0200
Hi
Wouldn't it be nice to specify the EPICS_CA_* values firstly through functions in the library rather than environment variables only.
And then secondly on a per-connection basis.
So you can have seperate setup for every PV connection. ?
Is it possible to link casw into a program somehow? So that your client program can monitor the status of a specific IOC?
It would be nice if the ARRAY_SIZE_LIMIT thing be done differently? Maybe removed all-together? Or be implemented in a way that it can be easily changed on the fly inside a program - The documentation aint very clear if this env-var is read while the program is running or only on startup?
Then a question:
Can somebody explain the relationship between.
ca_flush_io
ca_poll
ca_pend_io
ca_pend_event
And which ones of these I don't have to call in a enabled pre-emptive callback environment?
And lastly - with the CA library.
How do I control users - password ect in case of Access Control on IOC's ?
Thanks you for your answers in advance :)
-Heinrich
Re: CA wishlist :) Ralph Lange
Re: CA wishlist :) Kay-Uwe Kasemir
RE: CA wishlist :) Jeff Hill
Prev: MAXv firmware corruption Rarback, Harvey
Next: Re: CA wishlist :) Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: how to stop ca monitor Zhong Ren
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
