For anyone upgrading to Tornado 2.2.2 (VxWorks 5.5.2); be aware that there is a problem with target shell redirection. Here is how I described it to Wind River Systems (WRS) in the TSR; WRS tells me that since there is a workaround (i.e., use ld 0,0,"filename"), this will notIf the loader (ld) is invoked from the startup script using the redirected input format (e.g., ld < test.o) rather than the file format (e.g., ld 0,0,"test.o"), then no further redirected input from the startup script will work. get fixed until the next cumulative patch release (Tornado 2.2.3?). Ron
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
