1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: alh not handling log files correctly
To: Janet Anderson <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Mon, 05 Nov 2007 09:55:45 -0800
Thanks Janet,
I just had a report that a segmentation fault occurs when the 'silence alarms for one hour' selection is made. I verified that with this setup:
./alh.sh: line 10: 22836 Segmentation fault alh -f /home/als/alsoper/alh -l /home/als/alsoper/alh/logs -global -m 0 -L -T als.alhConfig
Chris
Janet Anderson wrote:
If I remember correctly, the alarm log and the current alarm history display
new alarm events (changes in alarm fields STAT and SEVR) as they happen.
Existing alarms are not logged when the alarm handler starts up because they
are not new alarm events.
The -T command line option from DESY creates alarm log files with special
dated names which are automatically switched at midnight. This option must
conflict with the runtime log file name change option.
An -xml command line option was added to alh by SNS. If this flag exists
alh will use XML-ish format for log files and will print "XML!" to stdout.
If it is not present, alh prints "no XML!" .
Janet
Chris Timossi wrote:
I've downloaded an built alh1_2_23 for Red Hat Enterprise Linux.
There are several problems related to viewing / changing the alarm log file. It actually crashes if I attempt to specify a new alarm log file:
Setup -> New Alarm Log File Name
crconlnx1.als.lbl.gov% ./alh.sh &
[1] 32688
crconlnx1.als.lbl.gov% no XML!
*** glibc detected *** free(): invalid next size (fast): 0x0839e748 ***
./alh.sh: line 10: 32689 Aborted alh -f /home/als/alsoper/alh -l /home/als/alsoper/alh/logs -global -m 0 -L -T als.alhConfig
The View->Current Alarm History shows a blank window even though there are active alarms.
The View->Alarm Log File Window also seems to be missing items. Again, there is a PV in major alarm that I would expect to see in the log file.
Is the 'no XML!' message important?
Chris Timossi
ALS/LBNL
alh not handling log files correctly Chris Timossi
Re: alh not handling log files correctly Janet Anderson
Prev: Re: EPICS on Mac OS X 10.5 Bertrand H.J. Biritz
Next: RE: Stream device Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: alh not handling log files correctly Janet Anderson
Next: Stream Raw converter and un/signed integrer Emmanuel Mayssat
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
