1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Stream device
To: "Dirk Zimoch" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 5 Nov 2007 10:10:30 -0800
Hi Dirk,
Unfortunately this does not solve my problem.  I am using epics R3.14.9 and asyn 4-9.  This is the output I get with my simple test soft IOC:
zms@esaux1 $ ../../bin/linux-x86/atest st.cmd
#!../../bin/linux-x86/atest
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocagwfg")
epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest")
epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-9")
epicsEnvSet(STRM,"/afs/slac/g/esa/ilc/epics/modules/streamdevice-2-3")
epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
epicsEnvSet( "STREAM_PROTOCOL_PATH","../../atestApp/Db:.")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest
dbLoadDatabase("dbd/atest.dbd",0,0)
atest_registerRecordDeviceDriver(pdbbase)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
#asynSetTraceMask( "L0",0,255)
asynSetTraceMask( "L0",8,0)
dbLoadRecords("db/atest.db","P=AG:")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest/iocBoot/iocagwfg
iocInit()
Starting iocInit
## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Oct  2 2007
2007/11/05 09:51:13.140 AG:WFreq: asynError in write: L0 port is not connected
2007/11/05 09:51:13.141 AG:WFreq: @init handler failed
2007/11/05 09:51:13.141 AG:WFreq: Record initialization failed
Bad init_rec return value  PV: AG:WFreq ao: init_record
iocInit: All initialization complete
epics> 2007/11/05 09:51:23.143 AG:RFreq: asynError in write: L0 port is not conn
ected
exit
zms@esaux1 $
Here are my atest.db and atest.proto files:
record( ai,"$(P)RFreq"){
  field( DESC, "read frequency")
  field( DTYP, "stream")
  field( SCAN, "10 second")
  field( PREC, "2")
  field( EGU,  "Hz")
  field( INP,  "@atest.proto rFreq L0 8")
record( ao,"$(P)WFreq"){
  field( DESC, "write frequency")
  field( SCAN, "Passive")
  field( PREC, "2")
  field( EGU,  "Hz")
  field( OUT,  "@atest.proto wFreq L0 8")
# file: atest.proto
Terminator=LF;
rFreq{ out "FREQ?"; in "%f";}
wFreq{ out "FREQ %f"; @init{ rFreq;}}
Here is the tail end of constructed atest.dbd file:
device(waveform,INST_IO,asynFloat64ArrayWfOut,"asynFloat64ArrayOut")
device(asyn,INST_IO,asynRecordDevice,"asynRecordDevice")
driver(stream)
driver(drvAsyn)
registrar(asSub)
registrar(streamRegistrar)
registrar(asynRegister)
registrar(asynInterposeFlushRegister)
registrar(asynInterposeEosRegister)
registrar(vxi11RegisterCommands)
registrar(drvAsynIPPortRegisterCommands)
registrar(drvAsynSerialPortRegisterCommands)
variable(asCaDebug,int)
variable(dbRecordsOnceOnly,int)
variable(dbBptNotMonotonic,int)
variable(streamDebug,int)
And finally, her is atestApp/src/Makefile:
TOP=../..
include $(TOP)/configure/CONFIG
PROD_IOC = atest
DBD += atest.dbd
atest_DBD += base.dbd
atest_DBD += stream.dbd
atest_DBD += asyn.dbd
atest_DBD += drvVxi11.dbd
atest_DBD += atestSup.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
atest_SRCS += atest_registerRecordDeviceDriver.cpp
atest_SRCS_DEFAULT += atestMain.cpp
atest_SRCS_vxWorks += -nil-
#The following adds support from base/src/vxWorks
atest_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
#add a definition for each support application used by this application
atest_LIBS += stream
atest_LIBS += asyn
atest_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
Are you using earlier versions of Epics or asyn?  If you are using the same version of these two packages, am I missing something in my Makefile or some other files?
Thanks for helping,
Zen
-----Original Message-----
Sent: Monday, November 05, 2007 5:59 AM
To: Szalata, Zenon M.
Subject: Re: Stream device
Hello Zen,
I tested @init handlers with several devices today. I found that TCP ports as well as serial ports work as expected. The problem only occurs with vxi11 ports.
However, I got different error messages:
2007/11/05 13:57:32.057 gpib0,8 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/11/05 13:57:32.058 L0 vxiCreateDevLink failed for addr 8
2007/11/05 13:57:32.058 asynManager::asynConnectCallback, port L0 error calling
asynCommon->connect
2007/11/05 13:57:36.067 L0 vxi11 clientCall errno 0 clnt_stat 5 L0 vxiBusStatus RPC error : RPC: Timed out
2007/11/05 13:57:36.067 L0 asynGpib:srqPoll srqStatus error timeout
2007/11/05 13:57:40.077 L0 vxi11 clientIoCall errno 0 clnt_stat 5
2007/11/05 13:57:40.077 DZ:cmd: asynError in write: L0 RPC failed
2007/11/05 13:57:40.078 DZ:cmd: @init handler failed
2007/11/05 13:57:40.078 DZ:cmd: Record initialization failed
StreamDevice error messages start with "asynError in write: L0 RPC failed". All above is drvVxi11 or asynManager.
I tried to do some debugging with the asynTrace facility and found that the problem disappears as soon as I call asynSetTraceMask, even with a 0 mask!
Thus try this in your startup script:
asynSetTraceMask ("L0",8,0)
However, I still have not the slightest idea what goes wrong in the vxi11 driver.
I Hope this helps.
Dirk
RE: Stream device Mark Rivers
Stream device Szalata, Zenon M.
Re: Stream device Dirk Zimoch
Prev: Re: alh not handling log files correctly Chris Timossi
Next: RE: Stream device Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Stream device Mark Rivers
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
