Probably only true if you want to do that scan rate change in a running
system.
Generally: As soon as the hardware allows different scan rates, I would
always make the appropriate SCAN fields a macro that gets substituted
when blowing up the template database:
If you put one input plus the attached calc into a template DB file and
set both SCAN field to $(channel_scan), you can instantiate an arbitrary
number of those per-channel structures, specifying the scan period of
each of them (channel_scan=".2 second") to whatever seems appropriate.
Ralph
Rodney R. Porter wrote:
One disadvantage of this method is that if you ever want to change the scan
rate, the change needs to be coordinated between different records. Having
a process chain with only 1 record setting the scan rate makes it easier if
you ever foresee someone else wanting to change the scan rate.
- Re: lexical analyzer for .db? Rodney R. Porter
Re: lexical analyzer for .db? Noboru Yamamoto
<2007>
Re: lexical analyzer for .db? Ben Franksen
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
