1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Asyn Driver with PXA255 (gumstix) and a non-standard baud rate
To: Eric Berryman <[email protected]>
Cc: [email protected]
Date: Wed, 31 Oct 2007 13:25:53 -0700
Eric,
Are you saying that you were able to compile epics/asyn/etc on Linux and
on your gumstix?
E
On Wed, 2007-10-31 at 09:14 -0400, Eric Berryman wrote:
> Hello,
> For those that would be interested, here is one solution to using the
> asyn driver and a non-standard baud rate on a pxa255 (gumstix).  (If
> you also can't get setserial to work without too much effort)
> First, configure the port for some standard baud rate in your st.cmd:
> drvAsynSerialPortConfigure ("SRRGA","/dev/ttyS2", 0, 0, 0)
> asynSetOption ("SRRGA", 0, "baud", "38400")
> asynSetOption ("SRRGA", 0, "bits", "8")
> asynSetOption ("SRRGA", 0, "parity", "none")
> asynSetOption ("SRRGA", 0, "stop", "2")
> asynSetOption ("SRRGA", 0, "clocal", "Y")
> asynSetOption ("SRRGA", 0, "crtscts", "N")
> Then poke the divisor registers for your baud rate:
> ## For PXA arch to set 28800 baud rate
> ## Set DLAB bit to 1 to access DLL and DLH bits
> system("/root/pxaregs STLCR 0x87")
> ## Set Divisor to 32 for 28800 baud rate
> system("/root/pxaregs STDLL 0x20")
> system("/root/pxaregs STDLH 0")
> ## Set DLAB bit to 0 with 8 bit, no parity, 2 stop bit
> system("/root/pxaregs STLCR 0x07")
Asyn Driver with PXA255 (gumstix) and a non-standard baud rate Eric Berryman
Prev: Re: Is there any chance that I can change SCAN parameter dynamically? Emmanuel Mayssat
Next: Re: VMIC 2534 3.14 support? Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Asyn Driver with PXA255 (gumstix) and a non-standard baud rate Eric Berryman
Next: Is there any chance that I can change SCAN parameter dynamically? Zhichu Chen
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
