On Wed, 31 Oct 2007, Laznovsky, Michael wrote:
> Hi- does anyone out there have EPICS 3.14 support for the VMIC 2534
> module? The EPICS website shows only a 3.13 version.
I have the VMIC 2536 bi/bo module which should be very similar (also on
www.fel.duke.edu/epics/ ). I haven't looked at the 2534 manual, but I
suspect it should be a trivial port. You can also take a look at the 1182
(bi) and 2120 (bo) support on the same page.
> Found 3.14 support for VMIC 3122/4132 here:
> http://www.fel.duke.edu/epics/downloads/ (but haven't tried them yet).
They are for 3.14, but only with VxWorks. I am using the same device code
with both 3.13 and 3.14 so I'm not using the OSI layer at this point.
Let me know if you have any questions.
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
- Is there any chance that I can change SCAN parameter dynamically? Zhichu Chen
- Re: Is there any chance that I can change SCAN parameter dynamically? Ned Arnold
- Re: Is there any chance that I can change SCAN parameter dynamically? Maren Purves
- VMIC 2534 3.14 support? Laznovsky, Michael
Re: Asyn Driver with PXA255 (gumstix) and a non-standard baud rate Emmanuel Mayssat
Documentation on pv crawler, etc. Eric Berryman
<2007>
Re: VMIC 2534 3.14 support? Dale L. Brewe
Re: Is there any chance that I can change SCAN parameter dynamically? Luedeke Andreas
<2007>
