It would certainly be wise to understand the hardware before writing an Asyn driver for it. However you should probably have at least some understanding of how an Asyn driver behaves before you finish the kernel driver for the hardware. We purchase the cards locally (might be ADLink). Make sure that you check out the Comedi website that Emmanual mentioned, their supported hardware mentions a number of ADLink boards for which drivers are available: http://www.comedi.org/hardware.html Has anyone else written Asyn drivers for boards using Comedi? We might also buy Correct, the internal Linux kernel APIs used by kernel drivers are significantly different between 2.4 and 2.6, and can change between different minor releases of 2.6 (2.6.23 is very different to 2.6.1). The way to install driver for cPCI cards is similar or not? A cPCI driver will be very similar to any other in-kernel PCI driver. One more question, is it difficult to handle interrupt from cPCI cards? As Emmanuel has suggested you probably don't want to try and bring interrupt information all the way up to user-space â the various mechanisms available for signaling interrupts to user-space are significantly slower than handling the interrupt completely inside your kernel driver, but debugging code that runs in the kernel can be much harder than code running in user-space. Hopefully the Comedi drivers will save you from having to write much code. - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
