I dread the day I ever created the message box monitor. I was in the process of converting our control system to EPICS and was still thinking in the mindset of the previous tool. I created the message box widget for a specific application that used it to keep a running log of events using a single edm process. The problem is that EPICS does not guarantee the delivery of every message, instead it guarantees that the last message received corresponds to the most recent write (which is, of course, the precise behavior you want for device control when the network is clogged or cpus are being strained). If you do want to use the message box anyway, notice that the online documentation, which is admittedly somewhat terse, says "Data written to a string PV...". So, the intent of the widget is to log string pv data. In that EPICS allows all pvs to be considered a "string", other types will work but will never include a linefeed character. To force a linefeed, the string must contain "\n", e.g. "this is a test\n". John Sinclair Szalata, Zenon M. wrote: I am learning how to use EDM. I have created a message box monitor and connected it to a PV of type double. The soft IOC updates the PV value avery few seconds. A typical value is 9.1990930. In the message box I see 99999999... Where another 9 is appended to the first line each time the PV updates. In the message box properties there is nothing that controls formatting displayed values, nor is there a way to add a newline after each update. Are these somehow controlled via the IOC record setup? What do I need to do to have each full floating point value appear on a separate line? The same string of 9's appears in the log file.
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
