I've put together a simple set of steps to get started with ASYN/
VXI-11.. I've sent a copy to Zenon. If it's found to be useful
I'll put a copy on the EPICS Wiki.
On Sep 20, 2007, at 3:06 AM, Benjamin Franksen wrote:
On Wednesday 19 September 2007 21:37, Szalata, Zenon M. wrote:
I am having difficulties installing a support package for Agilent
E2050
ethernet-GPIB gateway device. I got the package from
http://www-csr.bessy.de/control/SoftDist/gpib/ The installation
instructions are not clear. This is an extract from the lanGpib.pdf
file:
This section explains how the lanGpib driver is installed in an
existing
EPICS environment. By far the easiest way to install the package
is to
create a seperate <top> area (named, for example, 'GPIB') with
makeBaseAp.pl (this requires that you use EPICS3.13.1 or later).
Copy the
tar file into the new <top> directory and unpack it. You may need to
adapt the config/RELEASE resp. config/RELEASE.<arch> to your local
EPICS
configuration. Then 'make' everything from the <top> directory.
First of all I assume that the author of the note ment
makeBaseApp.pl in
epics base? Perhaps not. The Makefiles which came with the
package are
inconsistent with existing file names and directory structure
created by
the makeBaseApp.pl. I am trying to install in the context of epics
R3.14.9. The instructions provided with the distribution seem out of
date. I guess I need up to date instructions. Any help will be
appreciated.
All the modules from that site are for EPICS 3.13 only. For 3.14
you should
use asyn. lanGpibSupport-2.4.c is a very old version that I don't
recommend
to use. I won't provide support or fixes for this version. I still
support
gpib-0.x, although it is not actively developed any longer and the
last
release is from Jan 2006.
Cheers
Ben
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Byte Order? Szalata, Zenon M.
- lanGpibSupport-2.4.c Szalata, Zenon M.
- Re: lanGpibSupport-2.4.c Benjamin Franksen
Re: Asyn/VXI-11 problems Eric Norum
Re: exceed Dale L. Brewe
<2007>
Deadlock on epicsEvent Denison, PN (Peter)
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
