Which version of the source is this patch against? The current CVS
version of src/libCom/osi/os/RTEMS/epicsMath.h is now nothing but:
* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
* National Laboratory.
* Copyright (c) 2002 The Regents of the University of California, as
* Operator of Los Alamos National Laboratory.
* EPICS BASE Versions 3.13.7
* and higher are distributed subject to a Software License Agreement
found
* in file LICENSE that is included with this distribution.
#ifndef epicsMathh
#define epicsMathh
#include <math.h>
#include <ieeefp.h>
#endif /* epicsMathh */
declares 'isnan' and 'isinf' as external functions but C99 demands
that they are macros and newlib-1.15 defines them as such.
Including RTEMS' epicsMath.h from a C++ or C99 source file
causes a compilation error.
The attached kludge fixes this.
In fact, using 'isnan/isinf' from code that claims to be ANSI
compliant
(EPICS base is usually compiled (gcc) with -ansi) is wrong. ANSI-C
code
should not assume these functions to be present.
-- Till
*** src/libCom/osi/os/RTEMS/epicsMath.h.orig 2007-09-18
12:38:39.000000000 -0700
--- src/libCom/osi/os/RTEMS/epicsMath.h 2007-09-18
12:46:28.000000000 -0700
*** 16,24 ****
extern "C" {
#endif
int isnan(double);
- int finite(double);
int isinf(double);
#ifdef __cplusplus
--- 16,29 ----
extern "C" {
#endif
+ /* T.S.; C99 demands that these are macros and newlib-1.15 defines
+ * them as such!
+ #if defined(STRICT_ANSI) && !defined(__cplusplus)
int isnan(double);
int isinf(double);
+ #endif
+ int finite(double);
#ifdef __cplusplus
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: ANSI source including epicsMath.h won't compile with newlib 1.15 (RTEMS) Till Straumann
- ANSI source including epicsMath.h won't compile with newlib 1.15 (RTEMS) Till Straumann
<2007>
<2007>
