declares 'isnan' and 'isinf' as external functions but C99 demands that they are macros and newlib-1.15 defines them as such. Including RTEMS' epicsMath.h from a C++ or C99 source file causes a compilation error. The attached kludge fixes this. In fact, using 'isnan/isinf' from code that claims to be ANSI compliant (EPICS base is usually compiled (gcc) with -ansi) is wrong. ANSI-C code should not assume these functions to be present. -- Till *** src/libCom/osi/os/RTEMS/epicsMath.h.orig 2007-09-18 12:38:39.000000000 -0700 --- src/libCom/osi/os/RTEMS/epicsMath.h 2007-09-18 12:46:28.000000000 -0700 *************** *** 16,24 **** extern "C" { #endif int isnan(double); - int finite(double); int isinf(double); #ifdef __cplusplus } --- 16,29 ---- extern "C" { #endif + /* T.S.; C99 demands that these are macros and newlib-1.15 defines + * them as such! + */ + #if defined(STRICT_ANSI) && !defined(__cplusplus) int isnan(double); int isinf(double); + #endif + int finite(double); #ifdef __cplusplus }
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
