1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: oscilloscope hardware selection
To: "Emmanuel Mayssat" <[email protected]>, "Chestnut, Ronald P." <[email protected]>
Cc: "Perazzo, Amedeo" <[email protected]>, [email protected]
Date: Fri, 14 Sep 2007 21:39:51 -0700
It is correct that the DC282 from Agilent/Acqiris is going to be used for the LCLS AMOS and possibly also for the LUSI experiments. Also XTOD has purchased them for the FEE (implemented at LLNL for LCLS)
At present we have it running under Linux but we are porting RTEMS to the cPCI Coherent Technology INTEL processor followed by the RTEMS driver for the Acquiris. We will be running EPICS as on other LCLS contols & DAQ hardware,
My guess it will take another 2-3 months for that since we don't need it any earlier, as usual priorities...
We have two of those waveform samplers at SLAC but will need to order more.
Amedeo (see cc above) will know the details.
Regards
Gunther
Dr. Gunther Haller
MS 96
SLAC/Stanford University
2575 Sand Hill Road
Menlo Park, CA 94025
(650) 926-4257 (voice)
(650) 926-2923 (fax)
Sent: Fri 9/14/2007 5:56 PM
To: Chestnut, Ronald P.
Cc: Haller, Gunther; [email protected]
Ronald, Gunther,
On Fri, 2007-09-14 at 15:28 -0700, Chestnut, Ronald P. wrote:
> Emmanuel,
> If "they" are using this at SLAC, I'd like to know who!
At LCLS, Dr. Gunther Haller is using an agilent Acqiris scope.
At least this is what I read in one of his presentations.
http://www-glast.slac.stanford.edu/Elec_DAQ/lcls/Reviews/Haller-Lehman-LCLS-Controls-7-07-v5.ppt
Not sure about the state of the development of epics on the
scope/digitizer.
In his presentation I read:
Up to 8 GHz waveform sampling, 1 usec record or 1-GHz, 500-usec window
At 120 Hz -> 100 Mbytes/sec
High performance to move or process data
Waveform is time-stamped via EVR
Respective beam-quality data is attached to each waveform
Agilent Acqiris 8-GHz, 10-Bit DC282 cPCI Digitizer Module
That's exactly what I want ! ;-)
> We have purchased a microIOC Scope (two channels) from COSYLAB to take a look at - only costs about $3500. If, of course, just has a Channel Access (Ethernet) connection.
Clearly not a scope in the league I am looking for.
(Bandwidth, sampling rate, memory size, etc. are out of range)
That can also explain why it is so cheap in comparison to the ones I am
looking at. I like Cosylab epics support nevertheless.
Emmanuel Mayssat
Lyncean Technologies, Inc.
650/793-0626
oscilloscope hardware selection Emmanuel Mayssat
Re: oscilloscope hardware selection Emmanuel Mayssat
RE: oscilloscope hardware selection Emmanuel Mayssat
Prev: RE: oscilloscope hardware selection Emmanuel Mayssat
Next: Re: host watchdog and PLC John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Question on Generating Messages Robert Horrox
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
