Hi Zen,
Building testIPServerApp/src/ipSNCServer.st requires the EPICS State
Notation Language module, seq.
If you do not have the seq module installed then make sure the line
defining SNCSEQ in asyn/configure/RELEASE is commented out:
#SNCSEQ=/corvette/home/epics/devel/seq/2-0-11
If you do that, then the EPICS build system should not try to build
testIPServerApp and you won't get the error.
If you do have the seq module, then make sure the above line is
uncommented, and correctly points to your seq location.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
> Sent: Wednesday, September 12, 2007 12:48 PM
> To: EPICS tech-talk
> Subject: Building asyn4-8
> Building asyn 4-8 failed with the error:
> Installing dbd file ../../../dbd/testIPServer.dbd
> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX
> -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall
> -g -fPIC -I. -I.. -I../../../include/os/
> Linux -I../../../include
> -I/afs/slac/g/esa/esalib/app1/epics/R3.14.9/base/include/os/Li
> nux -I/afs/slac/g
> /esa/esalib/app1/epics/R3.14.9/base/include ../ipEchoServer.c
> nux -I/afs/slac/g
> /esa/esalib/app1/epics/R3.14.9/base/include ../ipEchoServer2.c
> gmake[3]: *** No rule to make target `ipSNCServer.o', needed
> by `libtestIPServerSupport.a'. Stop.
> gmake[3]: Leaving directory
> `/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-
> 8/testIPServer
> App/src/O.linux-x86'
> gmake[2]: *** [install.linux-x86] Error 2
> gmake[2]: Leaving directory
> 8/testIPServer
> App/src'
> gmake[1]: *** [src.install] Error 2
> gmake[1]: Leaving directory
> 8/testIPServer
> App'
> gmake: *** [testIPServerApp.install] Error 2
> I see that there is a file
> testIpServerApp/src/ipSNCServer.st but it somehow did not get
> properly handled. What am doing wrong? Am I missing something?
> Thanks in advance,
> Zen
- Building asyn4-8 Szalata, Zenon M.
oscilloscope hardware selection Emmanuel Mayssat
<2007>
<2007>
