Hi Robert,
> When I tried using asynSetTraceMask with my ioc that was
> working using asyn 4.5, the ports that I set asynTraceMask
> for would no longer connect.
That is very interesting. When you set asynTraceMask that actually
results in a call to pasynCommon->connect. That happens at the time of
the call to asynSetTraceMask. So it is should be connecting to the
device at that point.
But then you have this line:
## Reboot the GPIB gateway
E5810Reboot("192.168.0.63",0)
I am not familiar with the VXI-11 and GPIB gateway, but is it possible
that rebooting the gateway is breaking the connection that has already
been made because you set the asynTraceMask?
Here are 3 suggestions:
- Remove the call to E5810Reboot temporarily to see if that fixes the
problem.
- Move the call to asynSetTraceMask to after the E5810Reboot call
- Put a delay (epicsThreadSleep) after the E5810Reboot to see if the
device is simply not quite ready yet to accept connections when iocInit
is run.
> -----Original Message-----
> From: Robert Emery [mailto:[email protected]]
> Sent: Thursday, August 23, 2007 11:02 AM
> To: Mark Rivers
> Cc: [email protected]
> Subject: Re: asyn 4.8 problem
> Mark,
> I made the changes to asynManager but that made no
> difference. I tried
> using the asynSetTraceMask but that did not give me any more
> information. When I tried using asynSetTraceMask with my ioc
> that was
> for would no
> longer connect.
> I have attached the outputs from various ioc configurations.
> Thanks
> Rob
> Mark Rivers wrote:
> > Rob,
> > We recently had a report from Dirk Zimich at PSI that VXI11 was not
> > working with asyn R4-8. But he was upgrading from EPICS
> R3.13, not an
> > earlier version of asyn. So your report is very useful,
> since you say
> > it worked in asyn R4-5.
> > Can you send the complete output when your IOC starts?
> > Can you set the asynTraceMask on that asyn port so that you get full
> > debugging information?
> > Also, I suspect that the problem may be coming from the
> code that was
> > added in asyn R4-6 to automatically queue a connect request (call to
> > pasynCommon->connect) when a call to
> pasynManager->connectDevice is done
> > for a port with the attributes autoConnect=Yes and isConnected=No.
> > Can you please try disabling this code with the following
> change that
> > comments out the call to pasynCommon->connect() and letting
> me know if
> > it fixes the problem?
> > corvette> cvs diff -rR4-8 asynManager.c
> > Index: asynManager.c
> > RCS file:
> /net/phoebus/epicsmgr/cvsroot/epics/modules/soft/asyn/asyn/asy
> nDriver/as
> > ynManager.c,v
> > retrieving revision 1.93
> > diff -u -r1.93 asynManager.c
> > --- asynManager.c 28 Apr 2007 21:19:58 -0000 1.93
> > +++ asynManager.c 22 Aug 2007 17:25:32 -0000
> > @@ -1185,6 +1185,7 @@
> > pasynCommon = (asynCommon *)pasynInterface->pinterface;
> > commonPvt = pasynInterface->drvPvt;
> > status = pasynCommon->connect(commonPvt, pasynUser);
> > if (status != asynSuccess) {
> > asynPrint(pasynUser, ASYN_TRACE_ERROR,
> > @@ -1192,6 +1193,7 @@
> > portName, pasynUser->errorMessage);
> > goto cleanup;
> > cleanup:
> > status = pasynManager->freeAsynUser(pasynUser);
> > Thanks,
> > Mark
> >> From: [email protected]
> >> [mailto:[email protected]] On Behalf Of Robert Emery
> >> Sent: Wednesday, August 22, 2007 11:25 AM
> >> To: [email protected]
> >> Subject: asyn 4.8 problem
> >> I have recently upgraded from asyn 4.5 to 4.8 and am seeing the
> >> following error messages whereas I didn't have them with 4.5:
> >> Starting iocInit
> >> ### EPICS IOC CORE built on Oct 9 2006
> >> ### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> >> 2007/08/22 09:01:13.319 gpib0,1 vxiCreateDeviceLink RPC
> error : RPC:
> >> Unable to receive; errno = Connection reset by peer
> >> 2007/08/22 09:01:13.319 CoilA vxiCreateDevLink failed for addr 1
> >> 2007/08/22 09:01:13.319 asynManager::asynConnectCallback,
> port CoilA
> >> error calling asynCommon->connect
> error : RPC:
> >> Unable to send; errno = Broken pipe
> >> I am using this to control equipment on GPIB via an Agilent E5810
> >> Ethernet/GPIB bridge.
> >> Any ideas?
> >> Thanks
> >> Rob Emery
> >> UW Medical Center
- Re: asyn 4.8 problem Robert Emery
Re: ethernet IP John Sinclair
Re: StreamDevice protocol question Rodney R. Porter
<2007>
Re: asyn 4.8 problem Matthew Pearson
<2007>
