Emma,
This sounds like a bug/feature. You might try %*[^E] instead of %*[.0-9]
and see if that works. It looks like your second example is trying to send
2 values to the same PV, which is probably not well defined. Depending on
how your input can vary, you could also try %*4c or %*i.%*i to skip the
input.
Personally, when a command is echoed back, I try to match, instead of
skipping, the characters as an added error check. Usually this means
copying part of your output statement into your input statement. This is
difficult if the number is a variable, as opposed to a constant.
Rodney R. Porter
X-Ray Nanoprobe Software Engineer
Advanced Photon Source Sector 26
Center for Nanoscale Materials
Argonne National Laboratory
On 8/23/07 4:29 AM, "Shepherd, EL (Emma)" <[email protected]>
wrote:
> Hi,
> I've been battling with a Streams protocol and thought I would ask for
> some advice from the experts!
> I have the following input from my Streams device: "RC1C0V0.00E2.50"
> Now this is just an echo of a command I have sent so instead of saving
> the information I want to use the * modifier to simply skip the floating
> point numbers, like so:
> in "RC1C0V%*[.0-9]E%*f";
> (NB: I am using a charset instead of %f for the first number since the E
> character could be interpreted as an exponent).
> This doesn't work, and I get the following Streams error:
> 2007/08/23 09:07:49.260 BLXXI-EA-LED-01:CH1SENDOUTPUT: Input
> "RC1C0V0.00E2.50" too short. No match for "E"
> However, if I remove the * modifiers and put field names there instead,
> it works fine:
> in "RC1C0V%(MYRECORD.VAL)[.0-9]E%(MYRECORD.VAL)f";
> If I leave the field name in for the first number and %*f for the second
> I get the following error:
> 2007/08/23 09:25:25.632 BLXXI-EA-LED-01:CH1SENDOUTPUT: Input "2.50" does
> not match format %*f
> Any ideas why I am not able to use the * flag in these cases?
> Thanks,
> Emma
> <DIV><FONT size="1" color="gray">This e-mail and any attachments may contain
> confidential, copyright and or privileged material, and are for the use of the
> intended addressee only. If you are not the intended addressee or an
> authorised recipient of the addressee please notify us of receipt by returning
> the e-mail and do not use, copy, retain, distribute or disclose the
> information in or attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and not
> necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments
> are free from viruses and we cannot accept liability for any damage which you
> may sustain as a result of software viruses which may be transmitted in or
> with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England and
> Wales with its registered office at Diamond House, Harwell Science and
> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
> </FONT></DIV>
- RE: StreamDevice protocol question Shepherd, EL (Emma)
- StreamDevice protocol question Shepherd, EL (Emma)
RE: asyn 4.8 problem Mark Rivers
Re: asyn 4.8 problem Robert Emery
<2007>
<2007>
