Rob,
We recently had a report from Dirk Zimich at PSI that VXI11 was not
working with asyn R4-8. But he was upgrading from EPICS R3.13, not an
earlier version of asyn. So your report is very useful, since you say
it worked in asyn R4-5.
Can you send the complete output when your IOC starts?
Can you set the asynTraceMask on that asyn port so that you get full
debugging information?
Also, I suspect that the problem may be coming from the code that was
added in asyn R4-6 to automatically queue a connect request (call to
pasynCommon->connect) when a call to pasynManager->connectDevice is done
for a port with the attributes autoConnect=Yes and isConnected=No.
Can you please try disabling this code with the following change that
comments out the call to pasynCommon->connect() and letting me know if
it fixes the problem?
corvette> cvs diff -rR4-8 asynManager.c
Index: asynManager.c
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/modules/soft/asyn/asyn/asynDriver/as
ynManager.c,v
retrieving revision 1.93
diff -u -r1.93 asynManager.c
--- asynManager.c 28 Apr 2007 21:19:58 -0000 1.93
+++ asynManager.c 22 Aug 2007 17:25:32 -0000
@@ -1185,6 +1185,7 @@
pasynCommon = (asynCommon *)pasynInterface->pinterface;
commonPvt = pasynInterface->drvPvt;
status = pasynCommon->connect(commonPvt, pasynUser);
if (status != asynSuccess) {
asynPrint(pasynUser, ASYN_TRACE_ERROR,
@@ -1192,6 +1193,7 @@
portName, pasynUser->errorMessage);
goto cleanup;
cleanup:
status = pasynManager->freeAsynUser(pasynUser);
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Robert Emery
> Sent: Wednesday, August 22, 2007 11:25 AM
> To: [email protected]
> Subject: asyn 4.8 problem
> I have recently upgraded from asyn 4.5 to 4.8 and am seeing the
> following error messages whereas I didn't have them with 4.5:
> Starting iocInit
> ### EPICS IOC CORE built on Oct 9 2006
> ### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> 2007/08/22 09:01:13.319 gpib0,1 vxiCreateDeviceLink RPC error : RPC:
> Unable to receive; errno = Connection reset by peer
> 2007/08/22 09:01:13.319 CoilA vxiCreateDevLink failed for addr 1
> 2007/08/22 09:01:13.319 asynManager::asynConnectCallback, port CoilA
> error calling asynCommon->connect
> Unable to send; errno = Broken pipe
> I am using this to control equipment on GPIB via an Agilent E5810
> Ethernet/GPIB bridge.
> Any ideas?
> Thanks
> Rob Emery
> UW Medical Center
- Re: asyn 4.8 problem Robert Emery
- asyn 4.8 problem Robert Emery
bug in Red Hat Linux g++ 3.2.3 Jeff Hill
Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Peter Zumbruch
<2007>
<2007>
